Reducing Capacity by modifying Conrods?
Would it be possible to build a 66mm stroke and 90mm bore engine at just under 2500cc's by modifying the conrods instead of using sleeved 89mm cylinders? If so which would be preferable?
Robert
Old 04-02-2005, 01:29 AM
Author of "101 Projects"
Wayne 962's Avatar
Changing rod length alone won't change displacement - it will just change the compression of the motor (it will lower it if you shorten the rods). You can possibly use a smaller journal on the crank, offset bore it on the original, and then increase displacement by using a rod with a smaller journal. This is how they stroked the 914 2.0L motor from a 1.7 crank.
But, this would be difficult, expensive, and complicated to do on a 911 engine...
-Wayne
Old 04-02-2005, 01:58 AM
Thanks Wayne - guess 89mm pistons and cylinders are the only way to go.
Robert
Old 04-02-2005, 02:04 AM
jluetjen's Avatar
Actually, that's roughly how they changed the 2.2 911 engine into the 2.4.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 04-02-2005, 06:18 AM
Robert,
There is a place in Australia that does a lot of the offset grinding on VW cranks.
Michael
Old 04-06-2005, 07:11 PM
