KevinG's Avatar
Oil Leak on top of '70 MFI motor
Finally got it on the road, but found I have an oil leak on the top rear of the motor (center just to the right of the MFI pump). I will be looking at all of the potential areas thermostat, oil pressure sender, breather tube housing, etc. but early indications are the pressure? hose to the MFI pump.
This is the only piece in the area that I didn't replace, because I couldn't find one. Pelican doesn't stock it, and my PET doesn't even show it for a part number. Any help on sourcing one would be appreciated.
I did find that Pelican can obtain what is shown as a reducing socket so that I can bypass the oil feed and return hoses to the MFI pump and seal off the pump connections.
Kevin
1972 T Targa
Old 03-28-2005, 01:15 PM
MBEngineering's Avatar
HI part No' for pipe is 901 110 041 01 oil feed for the inj' pump, look on the PET page for the 911. 72. (mg)1, (sg)04, illustration No104-25
regards mike
Old 03-30-2005, 01:40 PM
KevinG's Avatar
Thanks Mike!!!
Kevin
1972 T Targa
Old 03-31-2005, 09:18 AM
Author of "101 Projects"
Wayne 962's Avatar
Here's the link to this part in our catalog:
http://www.pelicanparts.com/catalog/shopcart/911E/POR_911E_oilsys_pg3.htm#item9
If you ever can't find something, drop us a line through the Pelican Parts Message Center or pick up the phone...
-Wayne
Old 04-02-2005, 02:52 AM
