Dadofour's Avatar
Just getting Started - Engine Stand Question
Hi! I'm just getting started and want to get the right equipment.
Do I need both the OTC engine Stand and the P201 mount, or is the OTC Stand adequate by iteself?
I have read Wayne's book once, and will do it again before getting started. The information here is invaluable.
Than
My Track Schedule
1984 911 Viper Green Track Car - Parted out to fund
1993 BMW 325is Spec E36 Race Car
Old 04-02-2005, 05:22 PM
Jeff Alton's Avatar
I used the original universal adapter once. Now I have 2 P201s....
jeff
www.turn3autosport.com
Old 04-02-2005, 05:44 PM
Dadofour's Avatar
Is the universal adapter part of the OTC stand?
Does the P201 work with the OTC stand?
Than
My Track Schedule
Old 04-02-2005, 06:51 PM
Banned
snowman's Avatar
Do a search on engine stands. The subject has been beat to death, trampled upon, and then beat to death again and again.
Old 04-02-2005, 07:36 PM
diy83sc's Avatar
Dadofour,
DTM, right? We met at Limerock last year. When I am done with my rebuild, you can use my stuff (P201 nad 1250lb stand.) Some older stands do not have a large enough receptor for the P201. You have a PM with my email and cell.
Tony
Old 04-03-2005, 07:49 AM
Dadofour's Avatar
Tony,
Yes, I do remember. Yes, DTM! I will be at Lime Rock Thursday and Friday. If you are there, look for my Viper Green 911. Is yours the White rebuilt 911??
Than
Than
My Track Schedule
Old 04-03-2005, 01:02 PM
Drive it like u stole it.
jonesb930's Avatar
I used the proper Yoke but installed it into a cheep Auto Parts store stand. After looking at the setup I decided to pay the extra money for the OTC 4 wheel stand that has the U shaped legs. By having the middle of the stand opened I can slip my DK 20Q 4400lb Floor Jack (from pelican of course) right under the stand and lift the engine off. This eliminates the need for an engine crane. The nice thing about the AC jack is that it has a very high lift (needed to reach the motor on the stand). The stand cost around $150 I think. It is very heavy duty and well constructed. The jack may seam a little pricy but trust me, it is well worth the money. It is a very nice addition top the garage.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 04-04-2005, 05:58 AM
MAGA
Tim Hancock's Avatar
If you are DIY type and can weld, you can make one up in short fashion. This one features bent 1/2 plates that contact the case surface. It does not allow you split the case, but once you are down that far weight wise, it would probably be ok.
It is mounted to a cheapo engine stand. You will want to fashion up a drip pan also. These cheap stands are rated to 750 lbs, but I fashioned a wood post underneath until I stripped some weight off in the teardown just for insurance.
It is tough to justify spending $300-$500 for something you plan on using once
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 04-05-2005, 09:31 AM
rotorhead's Avatar
I know that it is not politically correct, but I just rebuilt my 3.3 turbo on a universal stand mount with a couple of 1/4" aluminium spacers to protect the transmission lip. I know I should have used a P201 but being on the other side of the planet I had to make do. My fully dressed 930 turbo motor was on it for a few weeks. (I would not have attempted it with a mag case). Just because I got away with it doesn't mean that others will, so I am not advocating it. I can post a pic if you like.
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 04-05-2005, 10:07 PM
Banned
snowman's Avatar
I did that with a mag case and "got away" with it.
Old 04-06-2005, 12:37 AM
Hi
I did it with a universal stand with some large washers as spacers (some cut in half to protect the lip) on a 2.4 7R, Its all you really need to distribute the load where the bolts go. I'd probably do something a little better next time, probable fabricate some 'feet' to fit other the U stand tubes
HTH
Neven
Old 04-06-2005, 12:43 PM
Banned
snowman's Avatar
For those who don't get away with it, there is always time certs, case welding, to fix almost any problem.
Old 04-06-2005, 08:40 PM
Jack
Its hardly a case of 'getting away with it', after all these bolts hold the same load if not more when the engines in the car, The only damage I could see being done is dinging the transmission mating lip
Neven
Old 04-06-2005, 08:58 PM
rotorhead's Avatar
---- deleted my own post cause this has been well covered in other threads ---
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 04-06-2005, 09:11 PM
Nah, The only difference would be that when up the right way the bottom bolts are in tension on the stand and the top bolt in the car. There is no 'torsional' load on the bolts, a minor amount of shear due to the engine torque (if thats what you mean). What you have to consider is that on the stand the bolts support the engine, in the car the support half the engine mass (as it is on the stand as the engine is supported at the front in the car) but also the half gearbox mass. Someone may have calculated these 'static' loads but I think you'll find they are very small in comparison to the strength of the bolts
Neven
I can draw a picture and
Old 04-06-2005, 09:20 PM
rotorhead's Avatar
Sorry Neven... I edited my post as you must have been writing your relpy. I feel a bit silly now
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 04-07-2005, 12:40 AM
