Grand Am/IMSA Data Guy
Porsche84's Avatar
Which oil pump to use
I am rebuilding a 72 T engine for street use. I need an oil pump. Which one is the best choice without breaking the bank? Thanks
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 04-08-2016, 05:02 PM
Use what is called the 4 bar pump for the 4 ripples on the back of it.
You need to do the oil bypass mod but it's the same pump used through Carrera
Bruce
Old 04-08-2016, 06:09 PM
SoyRacer's Avatar
Bruce
As stated by Bruce.
An SC pump will be a swap in and you'll be able to re-use the sump and screen.
Also it's an aluminum pump which is very much an upgrade.
Am bringing a couple to Hershey to sell.
RR
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 04-09-2016, 12:15 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The separate sump screen/venturi is not getting any younger and i've seen them break in the recent past. If I were looking for a pump, i'd get one from a Carrera 3.2 engine since it has the built in screen. The solution to the sump plate is get an aftermarket billet piece like Mainely or Burnham/Supertec
Kevin L
'86 Carrera "Larry"
Old 04-11-2016, 07:55 AM
gearhead
Just have Glenn Yee go through your stocker.
http://www.glennyeemotorsports.com/downloads/gt1_oilpumps.pdf
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 04-14-2016, 05:23 AM
It's a 914 ...
stownsen914's Avatar
Interesting. I like this idea. With the additional benefit of having someone knowledgeable go through the pump. They aren't getting any newer ...
Old 04-14-2016, 07:14 AM
gearhead
Ollie's keeps Glenn's pump on the shelf on a core exchange basis for people who don't want to wait for Glenn to rebuild their original as well.
I've visited Glenn in his shop and he walked me through his process. Next engine I build or have built will get one for sure.
1974 914 Bumble Bee
2009 Outback XT
Old 04-14-2016, 08:11 AM
3 restos WIP = psycho
kenikh's Avatar
Agree. Aaron Burnham once told me he could get an early pump to flow almost as well as a turbo pump just by fully relieving the internal breaking edges that interrupt flow. It's actually pretty simple to do yourself if you are handy with a Dremel.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-14-2016, 04:04 PM
