911 tweaks's Avatar
disposable wipes...what is everyone using?
I wish to know what you all are using for disposable wipes to wipe down the surfaces of new engine & trans parts as the final cleaning BEFORE assembly...
I cant find "chem-wipes" someone said in a recent post to use... cant find the "kim-wipes" our host used to carry... maybe I am putting in the wrong name/spelling???
Any value in using wipes already containing acetone??
Is it best to get white colored ones so no coloring comes out when exposed to a solvent prepped wipe??
What is the class level to best use to not have lint issues... "class 1" I believe is the absolute zero lint ones and you go up from there to "class 10"... "class 100"
where to get what is suggested best to use??
Thanks for your input!!
Bob
I live for 911 tweaks...
Old 05-01-2008, 02:03 PM
I got my Kimwipes at Office Depot. Looks like there's plenty of online suppliers as well.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 05-01-2008, 04:27 PM
304065's Avatar
Cleanroom wipes from McMaster
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-01-2008, 04:47 PM
911 tweaks's Avatar
thanks Brian & John.
Am I correct that I want class 1 grade??
What about the acetone impregnated wipes... a good idea for cleaning parts as it evaporates and leaves no residue that I know of?
Thanks, Bob
Old 05-01-2008, 06:44 PM
3.4 Bigger is better
88-diamondblue's Avatar
Bought Kim Wipes at a local medical supply store. Around $4 a box and no lint
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 05-01-2008, 07:18 PM
Kim Wipes are manufactured by Kimberly-Clark under the KimTech Science range.
You should be able to find them on their website and find a supplier that way.
andy
Old 05-01-2008, 08:42 PM
911 tweaks's Avatar
thanks all for your help
Bob
Old 05-02-2008, 05:16 AM
304065's Avatar
I use Eastwood PRE which is a bunch of solvents in a spray can. You can take a "clean" part like a chain box cover and spray it with the PRE and spend a few minutes rubbing and the clean-room wipe comes away black with dirt and accumulated crud.
Of course you should use a respirator certified for organic vapors, safety goggles and nitrile gloves. With all these solvents it's so easy to avoid exposure and only takes a couple minutes to protect yourself.
'81 R65
Old 05-02-2008, 05:57 AM
Personally, I wouldn't go that route because I like the Kimwipes to be a blank slate so I can use whatever of many different solvents for the specific task at hand. I guess what I'm saying is I use the Kimwipes for a lot of different things, including cleaning and detailing. If they were pre-impregnated with a solvent such as acetone, that would be a limiting factor in the wipes' usage.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 05-02-2008, 05:58 AM
911 tweaks's Avatar
John: I just went to the mcmaster carr site and 2 wipes seem ok??
Chem resistant #6209T1 (clean room class 100) and Heavy duyt #98465T64 (clean room class 10).
Can you help me out as to what you use and what class level do I need?
What wipes are you using?
What "solvents/cleaners) do you use on engine assembly... probably a multi step process with different chems for each? Maybe you have done a post on the prep ~ cleaning process for assembly?
Thanks for your help!
Bob
Thx Brian... good pt to not be boxed in w/ preg wipes as different chems needed/used for different apps
Old 05-02-2008, 07:21 AM
In a pinch if nothing else is around cans of brake clean, toilet paper, and compressed air.
Canned air will work if no compressor is around.
Blasts of air will blow off any toilet paper lint sticking to the cylinder walls before oiling them and installing the pistons.
Of course if you can get the lintless wipe pads like hospital grade pec pads, thats better.
Old 05-02-2008, 10:30 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I would stay away from acetone. The clean-room wipes I use are soaked in 70% IPA 30% DI water. They work well on most cleaning applications.
The class designation might be the ISO classification for airborne particle levels in clean rooms. Since you are not working in a clean room environment any class is fine. Even class 10,000 is cleaner than you average air in the garage or house. Your typical air in the house is around class 1,000,000. See here for more details: http://en.wikipedia.org/wiki/Clean_room
Ingo
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-02-2008, 12:50 PM
911 tweaks's Avatar
Thanks guys.
I will buy a box of several types and rating and see how they go... I will also try some of the eastwood "PRE" cleaner. nitrile gloves & air mask John suggested.
After I get parts back form machine shop, I want to be able clean properly prior to assembly.
Thanks again guys
Bob
Old 05-02-2008, 04:23 PM
