-   -   Question about engine install (http://forums.pelicanparts.com/911-engine-rebuilding-forum/215684-question-about-engine-install.html)
hobieboy 04-11-2005 08:28 AM
So this is the 2nd time I've done it and I seem to always run into the problem where a home-brew pry bar made up of a 2 feet long 1x2 is needed to convince the engine mount bar to flex enough to line up with the engine mount.
And it always take me hours (I spent 4 hours to line up the 4 bolts last night) to line everything up. As background - I use a motorcycle jack to hold the engine/tranny so its very stable.
Is there a trick that I miss to get that last millimeter of alignment?
jpnovak 04-11-2005 09:25 AM
Is the tub square? Is the motor bar straight? Did you mount it backwards on the motor?
You can also loosen the motor mounts in the chassis. There is a few mm of adjustment. Just make sure to tighten them down before you get them on boost. :)
hobieboy 04-11-2005 10:01 AM
I haven't sent my car to a jig so can't be 100% sure but there's no sign of accidents/repair done ever. And everything shuts properly.
The motor bar is new from my 1st rebuild. We did lossne the motor mounts in the chassis & in my case, there's maybe 1mm of adjustment... Now, after the bolts went in, its straight (can use finger to tighten them) so it seems like I just need a trick to line up the chassis/engine/tranny to the exact millimeter.
