clarelaw's Avatar
cheking cam timing in the car
I want to recheck my cam timing prior to firing the motor up again after a rebuild. I understand that it can be done in the car but that it is a pain in the a**.
Is it easier just to pull the engine, or just deal with the tight space and recheck it in the car?
1981 911SC - Targa
1981 Vanagon -
1996 Honda Accord (wife's car)
1973 914 1.7
Old 04-11-2005, 09:13 AM
clarelaw's Avatar
Come on guys - somebody out there must have tried to check ther cam timing with the engine in the car. I know it is not easy, but is it worth the hassel of pulling the engine, if that is the only reason to pull the engine?
1981 911SC - Targa
1981 Vanagon -
1973 914 1.7
Old 04-11-2005, 02:09 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Easy to do with engine in the car. Remove intake valve covers, place z-block and dial indicator on #1 intake spring retainer and rotate the crank pully to TDC, read lift. Do the same with #4. Easy as pie.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 04-11-2005, 02:31 PM
clarelaw's Avatar
Thanks, didn't want to pull the engine again.
1981 911SC - Targa
1981 Vanagon -
1973 914 1.7
Old 04-11-2005, 04:09 PM
just get the a/c pump out of the way. you can't line up the Z1 mark on pulley with the split in the cases, just the mark on the fan housing, which may or may not be right on, but it's within a few hundredths of a mm on the gauge, which is no big deal.
206 637 4071
Old 04-11-2005, 06:24 PM
clarelaw's Avatar
Thanks John, When I finally get this thing running half way decent, I'll bring it to you for a fine tune.
1981 911SC - Targa
1981 Vanagon -
1973 914 1.7
Old 04-12-2005, 09:00 AM
Irrationally exuberant
ChrisBennet's Avatar
Without the chain tensioned the cam timing will be a bit off but you'll be able to tell if you are in the ballpark.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-12-2005, 10:50 AM
