Sealant on 3.6 cam housing & cylinder?
Some differences between the 964 3.6 and the earlier include the cylinder base gasket is a Viton O-ring instead of the copper o-ring, the chain housing to engine case seal is metal, and the chain housing cover seal is plastic.
My question is, should I use a sealant such as Curit-T or Loctite 574 on these seals to prevent leak?
Here is the chain housing and seals.
Here is the cylider and seal.
thanks,
anthony
Old 04-15-2005, 06:20 PM
they seem to work ok as is, when they're fresh.
206 637 4071
Old 04-15-2005, 06:41 PM
Would the sealant help? Or will it preven the O-rings/seals from working properly?
thanks,
anthony
Old 04-16-2005, 01:04 AM
Bill Verburg's Avatar
You might want to read this thread
Bill Verburg
Old 04-16-2005, 06:40 AM
