3.0 Performance Enhancement
Has anyone had direct experience with changing cams and exhaust on a 3.0 engine to increase horsepower? Any idea on actual results? What about power curve change? What about durability? Comments please!
Old 04-19-2005, 06:12 PM
Alan Cottrill's Avatar
do a search using these terms
964 cams
20/21 cams
ssi
big AL
'77 911
Old 04-19-2005, 08:43 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
hmmmm, my dad has a 78 3.0 motor in his 74. The motor has the "usual" updates/backdates" as you will. SSi heat exchangers, two in two out muffler, 20/21 cams, msd 6al box and coil, advanced timing slightly. The motor feels very good, strong all around but really comes on around 3500. Also helps to have a 74 tranny with the lower gear ratio and a 2200lb car.
74 911s neverending story. two feet and a jetta for now.
Old 04-19-2005, 09:06 PM
Halm's Avatar
http://www.pelicanparts.com/techarticles/911_engine_rebuild/911_engine_rebuild2.htm
'17 Cayenne
Old 04-20-2005, 09:58 AM
Super Moderator
cstreit's Avatar
Durability with either of the aforementioned cams shouldn't be an issue Tony...
FYI you can't use a cam any more aggressive than those two on a stock 3.0L because of valve clearance issues with the pistons. Anything else requires new pistons...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-20-2005, 02:44 PM
Gentlemen,
Thank you for your comments/suggestions.
Tony
Old 04-20-2005, 05:05 PM
