Defective new Carrera oil pump
Defective new Carrera oil pump.
One of my long term friends has a track only 911 – a 2.8 ’69 911 that is very well professionally prepared. Here is the engine: 92x70.4 = 2808 cc, new Mahle Nikasil RSR P&Cs at 11.5:1, G-80 cams, perfect ’77 case, Motec EFI and twin plug. All the proper stuff nicely done. Normally run to 7600 RPM, probably capable of 8200 and more. Here is the oil system: New Factory Carrera oil pump 911.107.008.05. Dash-12 oil lines directly to front cooler with an in-line screen filter. No thermostat – just tape off cooler. No pressure relief in the scavenge circuit - just careful warm-up from cold. Front (smugglers box & above) oil tank. Dash-16 line back to pressure pump inlet with an in-line screen filter. Two separate breathers, one at the engine and one at the sump tank, each with a 1+ liter catch tank. No breather connection between the crankcase and the sump tank. Here are the symptoms: Increasingly there is oil pumped into the catch tank at the engine, none at the sump tank. At first there was none and eventually, after six hours total, 3-4 at-speed laps caused the crankcase to become full of oil, including the catch tank, and the oil sump tank too little. The oil pressure of course fluctuated and the car parked. Upon D&D (Disassembly and diagnosis): Rod bearings showing wear (expected due to the oil pressure fluctuation). Everything else was as expected EXECPT Here is the Factory new oil pump. The depth of the missing casting is about 0.20 mm. It covers about 70° of a total of 120° of the sealing surface of the scavenge gear pump. Clearly this may be the problem. My perception is the scavenge pump couldn’t keep up with the necessary oil flow. This was exacerbated by high RPM and increasing oil temperatures. While I prefer to have the crankcase breather connected to the sump tank (like Factory) this set-up has worked well for many. While there is an apparent cause, I’m not convinced. I fully expected to see a cracked oil pump from the lack of thermostat/pressure relief. With our collective knowledge, what else could be a cause? Replacing the oil pump is easy and no permanent damage was done. Is there something else here? My question to the Forum is: Separately or in combination with the scavenge pump, is there anything else that could cause these symptoms? Best, Grady |
Navin Johnson
That wear pattern looks odd. Wouldnt you expect it to be uniform?
Or its not a wear pattern at all.... A problem with the "Defective new Carrera oil pump" may have been there before you ever installed it Perhaps the the casting got fubared, the machining couldnt fix it.... who knows we just had a GT3 pump explode.. no pictures for forensics
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Looks like there was a void in the casting and after machining the chamber it was not properly inspected.
I would take it back and ask for a new pump and compensation for rebuilding the engine. When you get the new pump, check the inside before installing. Porsche may have a problem with this series of pumps (production run) and I'm sure they would like to find out. Bob
Bob Hutson |
