Southern Class & Sass
Dixie's Avatar
Help with oil switch seal
Hi all,
Figuring I’ll get quicker answer off the rebuild forum, I'll ask the same question I did in this thread. How do I get the aluminum seal that goes between the case, and the oil switch "stem" off? The seal is glued on with something.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 03-08-2008, 01:09 PM
dweymer's Avatar
Should just be a crush washer between the adapter and the case. If it is glued on, try something wooden, like a paint stirrer, and tap it lighty on the side of that. Or a gasket scraper slid between the washer and the case.
Donnie
Currently Porsche-less.....
Old 03-08-2008, 08:27 PM
