-   -   installing case savers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/220918-installing-case-savers.html)
philippeF 05-11-2005 01:14 AM
Hi
I'm going to install case savers in my 7R mag case, i've had a look at it, it seems there isn'y many material in this area ?.
any advice (a machine shop is doing the job...)
thanks
Philippe
afterburn 549 05-11-2005 12:29 PM
The 7R has room but you probbly want to "have it done" cause w.o. a proper jig you can end up saving lots of $$ but looking like a porkypine with none of them lined up and they have to be right on.
philippeF 05-11-2005 11:20 PM
Hi afterburner
i'm not doing the job, the machine shop will...
i wanted to be sure it's doable
thanks
Philippe
philippeF 05-11-2005 11:21 PM
to follow, there seem to be only 1mm of material on the cylinder side when the case savers are installed, is it enough?
cnavarro 05-12-2005 06:26 AM
It's tight, but in VW applications they sometimes have even less material around the stud boss or even have the case saver break into the spigot opening. You'll be better off with the case savers with less material between the case saver and the case spigot opening than you would be running the stud directly in the case. You might want to look into cryogenically treating your case- that will help significantly in preventing the studs from being pulled out.
afterburn 549 05-12-2005 03:20 PM
there is more then enough room there,but you dont want to take it to a shop that has never done it b4
philippeF 05-13-2005 12:42 AM
the shop i will bring it to is a engine specialist, i can do the job very well, i'm sure of that, may you confirm there is about 1 mm when installed ?
many thanks
Philippe
afterburn 549 05-13-2005 08:33 AM
I have no idea what your shop will be using....the proper ones are threaded on the out side and inside......there are some that will work but not as good-
philippeF 05-13-2005 09:56 AM
the case savers are ordered from pelican parts, so i believe they will fit right ?
thanks
Philippe
afterburn 549 05-13-2005 11:58 AM
corect.......but your machine shop may want to supply these.....kind of like taking food to a resturant and having it cooked if you take them the stuff.......just a thought
philippeF 05-15-2005 02:49 PM
don't really understand your opinion....
afterburn 549 05-15-2005 06:19 PM
some shops get a little up tight if you bring in parts to install....they loose thir mark up.....when I have to do that (take them the parts I just tell them to chage a little more and be happy about it. Just a comunication thing
philippeF 05-17-2005 12:19 AM
ok, you're right
but the guy is a friend of my best friend.....;)
