closing chain housing, sealant or not????
Hi,
I'm in the fase that i'm closing the chain tensioner housings.
In Wayne's book he states that all that's used is a gasket between the covers & housing.
On a lot of 911's I saw that an additional sealant was used. (574 or some silicone based sealant). Is this a proven procedure to assure a leak free engine? Is the gasket alone not enough?
If so, what's the best product to use? 574, Dirko or Curil T?
Thanks Hessel
Old 06-09-2005, 01:42 PM
I put mine in dry and to date I have no leaks.
Kevin
Kevin
'79 Coupe
Old 06-09-2005, 02:36 PM
Unregistered
sammyg2's Avatar
I used a very thin film of hylomar on mine with no leaks.
I have a hard time installing paper gaskets dry. Some times it is necessary, more often it is not.
I would not use RTV but that is a personal preference.
Old 06-10-2005, 03:20 PM
