-   -   Suggestions for warmed over 2.0 901/05? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/221927-suggestions-warmed-over-2-0-901-05-a.html)
ErVikingo 02-21-2007 11:30 AM
Without external cooling you are limiting the possibilities greatly. I had some radical thoughts but those require some nice coolers to keep things in check.... That's the subject of another conversation, perhaps for that 71 E PCA racer :D
In your shoes, I'd opt to get some Nickies due to the improved heat management (material, extra fins, ...) and perhaps consider overdriving the fan (knowing that there is a possibility of cavitation).
I'd also consider some of Sherwood's heat barriers (anything to keep heat away from the engine) and perhaps some creative use of underbody airflow. In this app. I think squirters would not be a must but would be nice and can't hurt).
JCF 02-22-2007 04:12 AM
Please, don't stop.
Grady Clay 03-02-2007 07:01 PM
John,
Remember, the fan ratio can negate the necessity for a front cooler on a “small” engine and you can change back & forth fans & pulleys without removing the engine. I have 1.82:1 on my 2.0 and 2.8S (of course the 2.8S needs the Rubbermaid Solution for track.)
Best,
Grady
Blake Meredith 03-03-2007 05:01 PM
The engine that I put in my 914 has a 2.4L crank with the 87.5 mm pistons with the Nickes. It has 46-40 valves with 36mm ports. GE 40 cams. I have 10 to 1 comp. I have not finished tuning it yet but is making 170whp and 160wtq at 5800 rpm. I have not dynoed it past that yet. I also do not have the 36mm manifolds for the carbs yet. Still looking for some. I hope to see almost 200 hp at the wheels when all is said and done.
Blake
Neil '67 911S 04-05-2010 06:11 PM
Originally Posted by Grady Clay (Post 3136673)
John,
Best,
Grady
What is/was the Rubber Maid solution?
Thanks!
Flieger 04-05-2010 06:59 PM
Spray water from a tupperware tub onto the cylinder heads or into the fan.
4ahickster 06-11-2010 05:53 PM
Have anyone tried Cheap Cylinder/piston sets?
Hi ,
I am Restoring a 68 911, The body has been lengthened to 69 spec, and is near all complete. I’m now turning my focus to the engine.
I have a 2.2 t all in tact that has been running but is need of a ring and valve refresh.
I also have a 2.4E that was rebuilt several years back but the previous owner let water get into a cylinder which cracked one cylinder.
My question is has anyone used those cheap cylinder/pistion set found on ebay?
My preference is to have the 2.4E as my engine.
I also see 2.2E cylinder/pistons sets for sale will these work?
I appreciate your reply
304065 08-17-2012 10:37 AM
It has all come full circle here:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/695849-assembling-1966-901-05-engine-phase-v-final-exam.html
http://forums.pelicanparts.com/uploa...1345170377.jpg
