Scargo2
Case-savers -Chicago
I have contacted 2 Porsche Independent service companies in the Chicago area and neither was evidently interested in R&R head studs and insert case inserts. I also checked with 2 "auto " machine shops and didn't want to touch. Does anyone know someone in Chicago area that would be willing to do it. Or do I have to pack it up and send them west. It is out, split and ready to go. It is a 77 2.7 no pulled or broken studs.
Old 06-21-2012, 11:13 AM
Apex?
Have you tried Apex in Bensenville?
Old 06-21-2012, 08:03 PM
Send it to Ollie's in Lake Havasu, AZ.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-22-2012, 09:13 AM
Ambitious Outsider
sabeo.m's Avatar
I've heard good things about Apex, I personally haven't used them.
I sent my entire engine to Ollie's, these guy's are fantastic. When I received my engine and parts back, I couldn't be more pleased with the worked they had preformed. Ollie’s is honest and reasonably priced. I would definitely used them again for any future rebuilds.
1988 3.2 Cab
2005 997.1 C2S
Old 06-24-2012, 03:01 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Send it to Craig Garrett (cgarr). He's in Michigan
Apex knows what they're doing too. Local guy recently used them and has very good things to say about them. If Midwest Eurosport uses them, then Apex knows what they're doing.
Kevin L
'86 Carrera "Larry"
Old 06-25-2012, 08:01 AM
Scargo2
Porsche Crest
Thanks for the response. I'll give Apex a try. As long as prices are line, it is less trouble and hopefully time. I'll post the results. Thanks again.
Old 06-25-2012, 11:13 AM
Give Bill at Apex a call.
He just did my heads, cylinders and cam towers did a great job and fair price. Turn around time was a little slow but he checks everything and only replaces what is necessary. Would use him again in the future.
Old 06-26-2012, 08:48 PM
Scargo2
Porsche Crest Case-savers Update
I promised an update. Apex did my case-savers and did a fine job. A Little slow, about a month, but if I had to ship to AZ or CA, it would have taken as long. Charged just under $500. Did an extra big-sert on an old helicoil repair (not case studs) at no extra cost. It probably took longer, because of his commercial accounts and racing season. Now I just need to get everything back together.
Old 08-16-2012, 10:49 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Thanks for the update. Every experience shared helps others know who to turn to for this type of work.
Kevin L
'86 Carrera "Larry"
Old 08-17-2012, 06:55 AM
