machine work on valve cover
I have a 6 hole lower valve cover with cooling fins. It is slightly warped, about .005 at one end. Can it be machined down flush or is it scrap? Thanks, Bill
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler... "The sea merely lies in wait for the innocent but it stalks the unwary." |
it can be resurfaced, but they're pretty flexable, and the .005 will pull in easy when the nuts are tightened. use the thick gray gaskets, not the hard thin green ones.
I had a similiar finding on mine but less than .0035, I plan to use silicone gaskets, do I still need to add gray gaskets that came with my rebuild kit?
Thanks, Alex
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
thick grey
I tried the thick grey gaskets and it worked out fine. Thanks,Bill
