New spring loaded tensioner install questions
I bought some new 930 spring loaded tensioners, and have a couple of questions about their installation:
1) I have the spacers for use with old idler arms. Even with the spacers on, there is quite a bit (maybe 1/4") of play for the idler arm to move back and forth on the shaft. It appears the very old (1970) tensioners also leave that play, so I guess it's normal for the idlers to seek the center from the chain, but I want to make sure.
2) The tensioners came brand new with a little clip going across the piston top, which is tucked under a circlip around the top of the tensioner itself. It looks like the circlip is holding a circular metal plate into the end of the tensioner. What's the procedure for releasing the tensioner? Install it, pull the clip off the piston, also pulling out the circlip? I would think you want to remove the clip holding the piston compressed, but leave the circlip, but it doesn't look like that's possible.
TIA
Jeff
'76 912E
'70 911T
Old 05-22-2005, 01:13 PM
