-   -   Piston to Valve clearance specs for 3.3L turbo (http://forums.pelicanparts.com/911-engine-rebuilding-forum/223205-piston-valve-clearance-specs-3-3l-turbo.html)
briankeithsmith 05-25-2005 08:42 AM
What is the piston to valve clearance spec for a 3.3L turbo engine with 964 cams?
Brian
camgrinder 05-25-2005 06:14 PM
1.5mm int 2.5mm exh.. in Waynes book there is a really good method for checking V to P.
350HP930 05-25-2005 06:35 PM
John, on your super cup cams do you happen to know what the exhaust valve opening is at TDC?
eimkeith 05-25-2005 06:44 PM
BrianKeef - still got that wastegate for me?
camgrinder 05-25-2005 07:33 PM
Tony,
I will look it up the lift @ overlap thursday and get it to you.
briankeithsmith 05-26-2005 05:37 AM
Keith, I told you it was a piece of junk...
brian
eimkeith 05-26-2005 02:13 PM
briankeef - can I have it or what? Your stuff is good stuff, man!
