Piston to Valve clearance specs for 3.3L turbo
What is the piston to valve clearance spec for a 3.3L turbo engine with 964 cams?
Brian
Brian Keith Smith |
1.5mm int 2.5mm exh.. in Waynes book there is a really good method for checking V to P.
John Dougherty Dougherty Racing Cams |
John, on your super cup cams do you happen to know what the exhaust valve opening is at TDC?
newb.
BrianKeef - still got that wastegate for me?
keith '75 RS/RSR-look | '73 CB750 | '70 TD250B r gruppe #436 |
Tony,
I will look it up the lift @ overlap thursday and get it to you.
Keith, I told you it was a piece of junk...
brian
Brian Keith Smith |
newb.
briankeef - can I have it or what? Your stuff is good stuff, man!
