-   -   3.9L slip ins for 964/993 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/223331-3-9l-slip-ins-964-993-a.html)
Marv's3.2six 05-25-2005 09:48 PM
Motor Me***** is selling a 3.9L 104mm slip in P&C set. (Read no machining) These are Alum cyls with Steel liners, allows for thin wall but very strong. Any builders on this forum use these? Anyone know who the manufacturer is? Is this good technology or smoke & mirrors?
Thanx in advance
Marv
Link to eBay auction for 3.9 P&C's
strokher racing 05-25-2005 11:25 PM
You will be much happier with the LNengineering stuff. I do know of a place who builds cylinders like these, but they are aimed at the turbo crowd.
Eric
cnavarro 05-26-2005 08:42 AM
My own personal experience with sleeved aluminum cylinders is that they do work *ok* when a liner is pressed into them, but I wouldn't exactly call it performance by any stretch of the imagination. You're loosing significant cooling and also lack sufficient sealing area for any long term reliability and longevity. I have a 100mm sleeved 930 cylinder in my office for which I am supplying replacements for just this reason. Not to push cylinders or anything, but you'll be happier with slip in 102s that are bored out and replated than having the added displacement. From our dyno testing, I would figure somewhere between a 7%-15% loss in HP going from a nikasil cylinder to a sleeved or straight up cast-iron cylinder. If you think the extra displacement will make up for that loss or this is just a weekend warrior, then go for it.
