3 restos WIP = psycho
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
abit off center
Craig
Banned
just pulling the chain to see what happens. Great response. No way would I put ANYTHING but a Porsche engine in a Porsche.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Craig:
Purdy motor .... I've got one too but, its in a 356. Jase |
I just bought Tony Corlett's book Porsche 911 3.2 Carrera and in th performance upgrade segment he talks about induction and exhaust mods.
" A Carrera with independent throttle bodies, a Motec EMS, 964 camshafts and an SSI exhaust should make close to 20 hp. Add in "S" camshafts and racing pistons and the Carrera 3.2 engine is good for 300-320 hp!" Granted this is for the Euro spec cars with 10.3:1 compression and no cat. Question, when he talks about 'independent throttle bodies' does he mean carbs ie PMO's or Webbers? Simon
85' Carrera 3.2 02' Mazda MX5 |
Oops I think I wrote 20hp when I meant 280hp.
Simon
up-fixing der car(ma)
Independent throttles are anything that have a butterfly for each cylinder.
For example, MFI, PMO's, Webers, TWM, etc. are all independent throttle bodies. The 3.2 has one big throttle body stock. BTW, when you calculate the cost of Motec($$$), $800 SSI's, and racing pistons (then you might as well make it 3.4L...), you are really upside down in that motor compared to a good 3.6L from a later 911.
Scott Kinder kindersport @ gmail.com |
as per bruce andersons book, 3.2 ss motor off a 3.0. head work(big ports) ge 80 cams, 46 webers, rsr racing headers (im sure you could substitute 993 heat exchangers for this or b&b.) page 152. motor makes 325+ at 7500rpm. fun stuff
74 911s neverending story. two feet and a jetta for now. |
A lot of these upgrades were developed well over a decade ago when 3.6's were not available so they have a different appeal to a similarly priced conversion.
Here in Oz there seem to be a lot more carb'ed 3.0 and 3.2 engines pumping out big horsepower compared to 3.6 conversions. Perhaps many of the older mechanics just liked building there own hotrods. Simon
