-   -   Oil lines with SSIs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/224157-oil-lines-ssis.html)
OldTee 05-31-2005 02:26 PM
Oil lines with SSIs
Could someone post a picture showing the location of the oil lines on a 3.0 SC engine being updated (downdated) with new SSI heat exchangers. I am about to mount the exchangers and it looks like it might be easier to install one of the oil lines now rather than later. I know I can figure it out with the engine installed but I am hoping a picture will save some time later. Thanks
wilke3169 05-31-2005 04:12 PM
The line that mounts to the engine needs to be installed prior to the SSIs. The tab on the line attachs near the oil cooler. This photo shows a small portion of the lines location.
http://forums.pelicanparts.com/uploa...1117581133.jpg
BReyes 05-31-2005 11:07 PM
Follow the picture above closely and you will see how it differs from the line you have now.
Yes you need a need line with SSI.
Regards,
BReyes 05-31-2005 11:08 PM
a new line
OldTee 06-01-2005 04:18 AM
Just what I needed. Thanks.:)
Bill Verburg 06-01-2005 02:14 PM
A pic from below
http://www.pelicanparts.com/MotorCity/wmv/964SSI2.jpg
and the wheel well area
http://forums.pelicanparts.com/uploa...ated_small.gif
