-   -   weber gasket sealant (http://forums.pelicanparts.com/911-engine-rebuilding-forum/224381-weber-gasket-sealant.html)
dimps8 06-01-2005 09:30 PM
Do you guys recommend using a sealer on the gaskets between webbers/insulation plate/inlet manifold? or just fit them dry. What does J.Walker do?
john walker's workshop 06-01-2005 09:43 PM
WWJD? no sealer.
dimps8 06-01-2005 09:50 PM
Thanks John. I'm also about to fix leaks on my 912 4 cyl, Going to pull the heads and replace pushrod tube o'rings and head stud seals. What do you recommend regarding new piston rings and a cylinder hone? I've got arias pistons on a cast iron 1720cc kit. Engine is not showing signs of getting tired nor any oil consumption.
jpnovak 06-02-2005 06:56 AM
I use a thin smear of Silicone vacuum grease (Dow 111). it prevents the seals from sticking and prolongs their life. It also does not flow/melt with heat.
john walker's workshop 06-02-2005 08:12 AM
i like goetze rings, but with arias pistons and an overbore, they probably are not available for that application. just try to find a basic cast ring set. no moly or chrome fancy stuff. you will have to measure the thickness of each ring and provide the cylinder bore. a few passes with a brush hone is all you need if the cylinders are new looking still. never hurts to run a dial bore gauge in them, as oversize cylinders are usually thinner wall and tend to get out of round.
dimps8 06-02-2005 07:00 PM
Thanks John. I'll measure the pistons etc and see if I can find some rings over your side of the planet.
