weber gasket sealant
Do you guys recommend using a sealer on the gaskets between webbers/insulation plate/inlet manifold? or just fit them dry. What does J.Walker do?
WWJD? no sealer.
Thanks John. I'm also about to fix leaks on my 912 4 cyl, Going to pull the heads and replace pushrod tube o'rings and head stud seals. What do you recommend regarding new piston rings and a cylinder hone? I've got arias pistons on a cast iron 1720cc kit. Engine is not showing signs of getting tired nor any oil consumption.
I would rather be driving
I use a thin smear of Silicone vacuum grease (Dow 111). it prevents the seals from sticking and prolongs their life. It also does not flow/melt with heat.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 06-02-2005 at 10:12 PM.. |
Thanks John. I'll measure the pistons etc and see if I can find some rings over your side of the planet.
