Question Oil fed tensioner update = loud whirring
After installing oil fed tensioners on my 82SC, I have noticed a prominent whirring sound from the engine that was not present before the upgrade. The whirring increases with RPM as expected and is close in sound to a square cut gear harmonic. To characterize the volume of the whirring, with the stock muffler, you could not distinguish the exhaust note over the whirring.
Before the upgrade, I did have one collapsed tensioner (loose chain) and one tensionser that appeared in better shape. During the upgrade, I only changed the tensioners, not touching the ramps, chains, or cam gears. After the upgrade, I am assuming both chains to be tighter than before.
I have posted this question on the 911 tech forum and was advised to post again on this forum.
I am wondering if this whirring is something to be concerned about or is the result of proper chain tension. I have read posts of others citing this phenomenon.
I have yet to pull the covers and inspect. Partially due to the fact that I am at a loss how to proceed.
Assistance is appreciated.
Marlin
82 911 SC
Marlin
82 911SC
Old 06-04-2005, 10:09 PM
For reference please see thread of same title on the 911 tech forums. Thank you to those who have posted replys on this forum.
Marlin
Marlin
82 911SC
Old 06-04-2005, 10:22 PM
After reading Waynes comments that preface this board, appologies for the double posting.
I did use the 101 Projects Book as a reference to perform the upgrade, but do not have any direct questions about the material contained within. Just a question about the result.
Marlin
Marlin
82 911SC
Old 06-05-2005, 06:49 AM
Marlin,
There shouldn't be a change in noise with the new tensioners. I would pull the covers off and see if you can find the problem. Some things to look at are: Is the chain aligned on all the sprockets (duplex chains so dual sprockets at each point). Is the idler sprocket arm moving freely on the rod it mounts on? Is a chain rubbing on something?
Sometimes the chains stretch and rub on the chain housings. If you can isolate which side you'll only have to remove that cover.
-Andy
Old 06-05-2005, 08:07 PM
