top end and connecting rod
I have my engine torn down and have noticed others having problems with connecting rods should I be checking or even changing the connecting rod fastners while the engine is this far apart?
Old 06-06-2005, 06:17 PM
I am doing a top end and replacing the rings with less than 100k
Old 06-06-2005, 06:18 PM
Jeff Alton's Avatar
What motor do you have?
Jeff
www.turn3autosport.com
Old 06-06-2005, 06:26 PM
1983 911sc 3.0
1983 911SC
1977 911S "parting out"
Old 06-06-2005, 06:42 PM
You'll notice that the only people with rod problems are 3.2 and 3.3 turbo drivers. Unless you race at very high RPM (over 7500) you don't need to worry about your rod bolts.
-Andy
Old 06-06-2005, 10:21 PM
1983 911SC
Old 06-07-2005, 10:33 PM
Jeff Alton's Avatar
You should be fine with the stock bolts.
Jeff
Old 06-07-2005, 10:50 PM
