top end and connecting rod
I have my engine torn down and have noticed others having problems with connecting rods should I be checking or even changing the connecting rod fastners while the engine is this far apart?
I am doing a top end and replacing the rings with less than 100k
What motor do you have?
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
1983 911sc 3.0
1983 911SC 1977 911S "parting out" |
You'll notice that the only people with rod problems are 3.2 and 3.3 turbo drivers. Unless you race at very high RPM (over 7500) you don't need to worry about your rod bolts.
-Andy
72 Carrera RS replica, Spec 911 racer |
You should be fine with the stock bolts.
Jeff
