Super Moderator
cstreit's Avatar
Is this a custom crank? Please help with ID
Well I finally measured and sourced the bearings for this 2.0L crank.
The motor is a 2.0L case with 84mm P's and C's. The crank takes .25mm over/under bearings for the mains and strangely, the rod journals are sized for a 3.0L (53mm) and it has 3.0L rods making it a short-stroke 2.0L.
Was there such a crank produced? ...or was this a custom dealio?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-07-2005, 09:36 AM
304065's Avatar
How many flywheel bolts?
It scares me to write this. . . with an 84mm bore, the only crank that gets you two liters is. . . a 60mm. . . which only appeared in . . .
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-07-2005, 11:22 AM
304065's Avatar
Typ 935/79, 935 "Baby", 71 x 60 (1425cc x 1.4 turbo multiplier for two liter class)
'81 R65
Old 06-07-2005, 11:32 AM
3 restos WIP = psycho
kenikh's Avatar
Is it April first again?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-07-2005, 12:51 PM
Super Moderator
cstreit's Avatar
No sirs.. No joke.
It's a 6 bolt crank. Alright, well either he doesn't know the true displacement (not that any racer ever "forgets") ... or what, it's a 935 crank?
Looks like I'll be measuring the stroke today.
Chris
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 06-07-2005, 02:24 PM
kenikh's Avatar
Keep us posted on this potential J A C K P O T.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-07-2005, 02:27 PM
304065's Avatar
Chris, I would NEVER accuse you of joking about a thing like THIS. It's too serious.
And it wouldn't be just a 935 crank, it would be a "Baby" crank-- the rarest of all!
The question (this should be answered by Grady) is was the 935 crank ever a six-bolt? I would have thought it would have been nine bolt by then.
Then again, if you measure the stroke, it might just turn out to be a 66mm crank, which would make it a bone-stock 2.0 liter. NOT that anyone's ever accidentally run 84mm jugs in a 2.0 class . . .
'81 R65
Old 06-07-2005, 02:28 PM
kenikh's Avatar
I assume it is counterweighted? If it weren't, I couldn't imagine it being a 935 crank.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-07-2005, 02:33 PM
Super Moderator
cstreit's Avatar
Yeah, it's counterweighted. So a 66mmx84mm would make it a 2.2... I'd be shocked if it were 60, but i'll check in an hour or so when I get back to assembly..
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 06-07-2005, 02:36 PM
adomakin's Avatar
excuse my ignorance but are they like really really rare? what sort of money would a usable 935 crank be worth?
Andy
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 06-07-2005, 04:36 PM
Super Moderator
cstreit's Avatar
An initial eyeball says 66mm, but I'll put a caliper on it and measure exactly when I drop the crank back in tonight... Dang...
Still, the 2.2L didn't have 3.0L sized rod journals...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 06-07-2005, 05:02 PM
304065's Avatar
Chris, a few specs from Wayne's book might be helpful.
Wayne's book is WRONG, on page 204 it claims a D1 dimension fir the 2.0 and 2.2 (66mm crank) of 57.010-57.059mm for the main bearing BORE, 56.971-56.990 SHAFT. According to the 2.2 spec book, its 57.020-57.059 BORE, 56.971-56.990 SHAFT. Now, the 2.0 spec book says 56.971-56.990, so that checks OK. That's a 6-bolt.
2.4/2.7/3.0 Turbo crank (70.4) 6-bolt, 57.020-57.059 BORE, 56.971-56-990 SHAFT. OK, that's the same as the 2.0/2.2 crank.
3.0SC 9-bolt (70.4mm) 60.020-60.059 BORE, 59.971-59.990 SHAFT.
3.2/3.3 Turbo 9-bolt (74.4mm) 60.020-60.059 BORE, 59.971-59.990 SHAFT. So that's the same as the 3.0.
Funny how Porsche changed critical dimensions barely through the 35-year run of the 911.
OK, you say it has 53mm rod journals. The rod journal is what the factory calls dimension "D2."
66mm- 57.020-57.059 BORE, 56.971-56.990 SHAFT
70.4mm- 52.020-52.059 BORE, 51.971-51.990 SHAFT
70.4 (9-bolt) 52.020-52.059 BORE, 51.971-51.990 SHAFT
74.4 52.020-52.059 BORE, 51.971-51.990 SHAFT
So, all the rod journals are the same after the 2.4-on.
That suggests to me it's either custom, or a ground undersize 66mm?
The mystery continues. . .
'81 R65
Old 06-07-2005, 07:23 PM
Super Moderator
cstreit's Avatar
Wow John, I think I inhaled too much carb cleaner to get all that in one reading. I didn't get a change to measure the stroke (assembled the short block this evening. I'm chomping to find out, but will have to check tomorrow. Thanks for the great info!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 06-07-2005, 10:03 PM
Alan.UK's Avatar
I really enjoyed reading this thread, and will be sure to check back soon.
Great info.
Alan.UK
Always learning
Old 06-08-2005, 01:04 PM
Super Moderator
cstreit's Avatar
Damned if I didn't bolt the heads on before I remembered to measure it! Argh! Well I'll try and get a feeler probe down in there to ballpark it later. I'm really doubting that it's 60mm though from when I looked at the dimensions earlier...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 06-08-2005, 05:24 PM
}{arlequin's Avatar
damn you... you tease!
dave
1973,5
Old 06-09-2005, 08:58 AM
304065's Avatar
And it shall remain a mystery until the NEXT rebuild. . . .20 years later, some young mechanic will tear it apart. . . kind of like the singing frog cartoon!
'81 R65
Old 06-10-2005, 07:07 AM
Send a message via AIM to 82SC
don't you want to be sure...
you could sell it to raise funds to fund your racing endeavors for the next decade...
MJ
Old 06-10-2005, 07:38 AM
304065's Avatar
"Everybody do the Michigan Raaaaagggg!"
'81 R65
Old 06-10-2005, 06:51 PM
kenikh's Avatar
You are a bad, bad man...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-10-2005, 08:20 PM
