Hbrand
hbrand's Avatar
Camshaft - valve hits piston
To prevent the exhaust valve from hitting the piston, I had to set the valve overlapp to 35mm instead of 67mm. Cam is 911R. number 901 105 103
What consequences does this have to the performance of my 2.8 high performance engine?
Dyno test right now shows 180 HP on rear wheels.
thanks, harold
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 06-09-2005, 10:57 AM
Irrationally exuberant
ChrisBennet's Avatar
Do you mean you used 3.5mm for the setting distance instead of 6.7mm? That change would retard the cam timing and move the torque peak up the power band wouldn't it?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-09-2005, 12:16 PM
camgrinder's Avatar
Should kill the midrange torque and move the powerband up.
3mm is enough to kill the power all over the band.
I would be curious what a compression test says...
John Dougherty
Dougherty Racing Cams
Old 06-09-2005, 10:32 PM
