Question Help on Rocker Arm Bushings
I stopped by my local Porsche dealer this morning to order some parts that I don't see at Pelican. While there I was able to get one of their Master Technicians to look at my cam shafts and a few of the rocker arms. One lobe had a pit in it near the edge. He said that it looked like an original imperfection and that the cams were not worn much and he wouldn't replace them.
I have kept the rocker arms in order and he said at most he would get the bushings replaced. He recommended a local machine shop to cut my valve seats and some other usual tasks including the bushing replacement.
The parts man could not find a number for the bushings alone.
I looked again on Pelican Web site for the bushing and find that you sell the complete rocker with the bushing.
I looked in Waynes book and found the part number both on page 64 and on page 217 with the parts listings.
I called the dealer back and was told that this part number was no go.
The part number in Waynes book is 901.105.043.98
Could there be a typo?
Anyone know a number that will work or where I can order the bushings?
Old 06-27-2003, 11:39 AM
Senior Member
Doug Zielke's Avatar
That number does not come up on PET.
I had my rocker arms re-bushed by Walt at Competition Engineering. Maybe he can help you.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 06-27-2003, 06:33 PM
Comp Eng
Yes it seems Walt is one of the few people around who will rebush rocker arms. He is redoing mine now. If you can measure your shaft OD's and rocker ID's (in two places) 0.003" tolerance is acceptable.
Arnie
'87 Carrera
2001 Beck 550
Old 06-28-2003, 05:05 AM
Redline did mine some years ago. Actually, they added bronze bushings to my early rockers which are bushing-less from the factory. Check with them as well.
Sherwood Lee
http://membersrennlist.org/911pcars
Old 06-28-2003, 12:26 PM
Thanks for the reply.
Is there a link for Redline?
What I am really looking for is the bushings.
Does anyone have a source for the bushing only. I have a great machine shop that can install them.
I will be reusing my camshafts and don't want or need the face of the arms reground.
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 07-02-2003, 06:45 AM
I don't have a contact for Redline (do a search on Google).
As for non-existent factory rocker bushings, check with all up all the usual sources (Stoddard?), then call any well-stocked bearing house. They can probably come up with some generic bronze bushings your machine shop can resize to fit.
Sherwood Lee
http://members.rennlist.org/911pcars
BTW, if you're not going to reface the rockers, try to ID them so they reinstall with the same cam lobe.
Old 07-02-2003, 11:56 AM
Any help with the ususal suspects would be appreciated.
Wayne, Is there possibly a typo on the part number in your book.
I was hoping Pelican might sell these or have a source?
Bill Miller
81 Targa Guards Red
Old 07-02-2003, 12:20 PM
I had Ollie's rebuild my rocker arms, which included new bushings and grinding the cam contact area. I think I paid $12 a arm.
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 07-02-2003, 08:04 PM
If you have no luck, I can make you some bushings, and get them a helluva lot closer than .003.
Old 08-10-2004, 05:11 PM
heres a set I just made for a differential housing.
Old 08-10-2004, 06:06 PM
Bird. It's the word...
Fishcop's Avatar
Pretty enough to wear as wedding rings
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 08-10-2004, 06:36 PM
Or put in the differential of a 700 hp race car and pound the living daylights out of for the rest of its life
I figured that when I meet the right woman, I will save the money on a rock and chuck up a peice of bar stock and turn her out something pretty bi tchin instead. Maybe she will wear it when she smacks me across the face for trying to skate on buying her a real ring.
Old 08-10-2004, 07:32 PM
Now in 993 land ...
aigel's Avatar
If I had the cam, holding it in my hand an it had a pit in it, I'd have it fixed, regardless where the pit came from or if it was on the edge or not. A side benefit would be the perfect chance to up the grind a bit, and get some extra umph. Get the rocker arms redone completely and start fresh. Nothing worse than putting something together that has known flaws. At least for me it is.
Just my two cents.
Cheers, George
81 SC (sold)
Old 08-10-2004, 11:54 PM
(What I am really looking for is the bushings.)
You can use a Repco part with a little triming F/N-RB-4037
I believe it is a Honda small engine Gudgeon pin bushing.
Best regards
Old 08-11-2004, 07:56 AM
Bill, I have 3 rocker arm bushings that I am not going to use that I'll sell cheap.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 08-15-2004, 10:52 AM
Anyone who knows what alloy to use when fabricating new bushes? I know the bushes should be press fit so I wonder what outer diameter should I use?
Tor Erik Schjølberg
85 911 Carerra
83 Ford Capri 2,8I
Old 08-26-2004, 08:10 AM
Wer bremst verliert
JohnJL's Avatar
Any update here? Bob Whyms in Sydney says they won't re-bush rocker arms anymore as they've had some seize upon being re-bushed.
Anyone in Sydney successfully have their rocker arms rebushed?
I guess I may just want new ones anyway since the camshafts are being reground...
thanks
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-22-2005, 06:14 PM
Fishcop's Avatar
John, these guys do a good job. I had them do S camshafts from a pair of CIS jobbies. They can recondition the rockers. I am a bad boy though, I used my old ones, bushes were fine and I refaced them myself...
http://tighecams.com.au/
John Forcier
Old 06-23-2005, 02:04 AM
Wer bremst verliert
JohnJL's Avatar
John,
Did they recondition your rockers for you?
Old 06-23-2005, 04:49 AM
