gumba's Avatar
mystery heads
911 104 306 date stamp 5/71 twin plug. intake approx. 37.2mm, exhaust approx. 34.9mm
Thanks for any help.
'74 rsr w/2.8 twin plug
Old 07-14-2005, 03:56 PM
Nitrometano's Avatar
If you look the date, maybe the heads come from a 2.2 engine.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 07-14-2005, 10:20 PM
BURN-BROS's Avatar
Are the spark plug holes the same size? Do they use the small spark plugs?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-15-2005, 06:49 AM
gumba's Avatar
The plug holes are the same size. Small plugs Bosch f3cs.
Thanks,
Harold
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 07-15-2005, 07:35 AM
BURN-BROS's Avatar
Harold,
This is stuff that you probably already figured out but I'll throw it out there. Sounds like factory racing heads. Ports are smaller than RSR so maybe ST heads. Sound like you got some good parts out of that race motor.
Burnham Performance
Old 07-15-2005, 09:56 AM
gumba's Avatar
Thanks for the help. I don't have a clue about the heads. The plugs are 14mm so they may be a stock early head someone twin plugged. I was able to look up the serial number on the cams, and "Camgrinder" confirmed it. I figured based on the cams I should keep investigating the rest of the stuff. My plan is to have the motor rebuilt and stick it in my '73 targa for the time being.
Harold
Old 07-15-2005, 10:33 AM
BURN-BROS's Avatar
Can you post pics? Take extra care of the crank too. You never know what it could be...
Burnham Performance
Old 07-15-2005, 10:41 AM
BURN-BROS's Avatar
Here is a pic of a 935 head for reference. note size of spark plug holes
Burnham Performance
Old 07-15-2005, 10:47 AM
gumba's Avatar
valves are approx. 45/40
Old 07-15-2005, 01:16 PM
BURN-BROS's Avatar
The larger sparkplugs make this a standard head modded to twin plug. Generally they use the smaller plugs to keep as much head material as possible for heat transfer.
Burnham Performance
Old 07-15-2005, 01:45 PM
gumba's Avatar
That's what I thought. Thanks for all the help.
Harold
Old 07-15-2005, 01:58 PM
