-   -   SSI heat exchangers for 3.4? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/228791-ssi-heat-exchangers-3-4-a.html)
quint22cp 06-29-2005 11:36 AM
During my engine rebuild I want to fit some SSI heat exchangers:- PEL-SSI-LT3.2 & PEL-SSI-RT3.2
I will also be increasing the capacity to 3.4L, are the primaries on these heat exchangers big enough to cope with this?
Has any one gone down this route?
Bill Verburg 06-29-2005 01:28 PM
from my personal experience SSI are fine for 3, getting too small for 3.2 and definitely too small for 3.6
All SSI have 1 3/8" primaries, I would look for 1 1/2" or maybe even 1 5/8" depends on other mods and intended use.
Wayne 962 06-30-2005 01:46 AM
It depends. Probably not ideal, but I doubt that you will feel any difference in HP. Probably the only real solution if you want heat...
-Wayne
quint22cp 06-30-2005 01:52 AM
I gott'a have heat this is the UK!
Summer only lasts 4 days and we just had them.
Are there any other SSI style heat exchangers on the market with bigger tubing?
Bill Verburg 06-30-2005 05:00 AM
B&B has both 1 5/8" OD and 1 3/4" OD w/ heat that bolts on. Or since you are in the UK Hayward &Scott may be able to help you.
A word of warning, the B&B headers are fine but do have a proprietary spacing for the muffler inlets. I wouldn't use the b&B mufflers too many headaches there. Fab up a Flo-master or equivalent.
something like this
http://forums.pelicanparts.com/uploa..._008_small.jpg
JeremyD 07-03-2005 08:21 PM
A question and a statement.
Question - Bill where did you get the heat set ups (especially the rears) Is that a B & B part.
Statement - Ben McFarland will be in receipt of a B & B muffler from me and will be making mufflers at some point for B & B headers.
Bill Verburg 07-04-2005 05:22 AM
When you order B&B headers you have several options
  • 1 5/8" or 1 3/4"
  • Carrera 3.2 heat inlets or 964 heat inlets
  • 911 heat outlets or 964 heat outlets
Mine are 1 3/4", 964 heat inlets and 911 heat outlets.
w/ that setup you use the stock 964 heat tube as pictured. I have used it on both 964 and 993 vram engines.
JeremyD 07-04-2005 05:29 AM
Great 0 thanks Bill - I have the 964 version - I'll have to look for a 964 heater cross over tube.
quint22cp 07-04-2005 05:32 AM
Bill,
Where did you buy your B&B?
I work in the US quite alot and I was going to buy them out there and carry them home.
Exchange rate is good at the moment!
JeremyD 07-04-2005 05:38 AM
Pelican Parts is a B & B Dealer -
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_exhaus_pg2.htm#item6
Steve Timmins at Instant G is also B & B Dealer - timmins@UDel.Edu
