Made in Flacht
jacksd3's Avatar
965 Deck Height
Since my '92' pistons are flatops I used the simple method of measuring deck height using a vernier caliper. I came up with about .5mm for each of the cylinders. The aluminum ring that goes between the head and the cylinder is about another .48mm. So it would seem like I'm well short of the 1.25 - 1.5mm standard. My cylinders use the 964 o-ring at the base of the cylinder so I can't gain anything there. What am I missing?
Thanks in advance!
1988 944S
2001 Boxster S Seal Grey, M030, PSM
2003 Ford F-350 Dually 6.0 litre Turbo Diesel - You think YOU got torque
1995 International 9200 Road Tractor 11 Litre Single Axle Daycab Eaton Super 10 Tranny
Old 06-26-2009, 09:10 AM
