Gear ratios
what gear ratios would you guys recomend for my 2.7 carburated 914 - 6. The box is a 901 and the diff is stock 914-4 for 73. I plan on driving the car on the street as well as autocross and track days so i looking for some balance to the ratios. Currently the gears are as follows A, F, L,O,V. I don't like the higher RPM IN 5TH for highway cruising. about 62 mph @ 4000. I know the gears are suited for auto crossing.
Let's see here . .. . V gets you 62 mph @ 4000 rpm, it is a 27/25, or .93 slight overdrive. Are you using a small tire with like a 20" diameter? That's the only way V would give you 62 mph at 4K, with a stock 7/27 ring and pinion.
Anyway, how about a ZA fifth? That would give you 77 mph with the same combo.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) Last edited by 304065; 10-13-2005 at 04:16 PM.. |
Try not, Do or Do not
A, F, M, S, X.
All around best 914/6 gearing for street with a 6800 RPM engine. They are stock/ production gears so there is no sticker shock when it comes to purchasing this combo. I have used this gear box on street 2.4- 2.7 for 20 years. It is the gearing I use in my 2.7 RS spec w/ solex carbs. in my 914/6 Couldn't be happier. Call and I'll quote a price for these gears. (trade ?)
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-13-2005 at 05:35 PM.. |
The stock 4 banger 901 gears are too short for a 6 cyl (7100 rpm or so) engine at AX. First is good for about 60 feet (useless except for starts), 2nd is good for about 58 mph with a 22.5 inch dia rear tire....I spend waay to much time on the rev limiter.
Most AXs are run in 2nd as they are set up for less than 60 mph *in an average car*....a 2.7L in a 914 is not average As I see it, you would want to slightly higher speed in the lower gears than what you will need....say 45 in first & 65 in 2nd. To that end, I've found a "B" 1st ....not easy to find, and a 904 mainshaft is on the purchase list along with something between G & H for 2nd depending on availability. Mine is an AX only car, but I can't see where this would hurt on either the street or track.
JPIII Early Boxster Last edited by J P Stein; 10-15-2005 at 08:23 PM.. |
Navin Johnson
thats what I have in my 914/6 in my 911 I have A,GA,K,Q,V which doesnt help you a bit
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
A, Ga, K, Q, V sounds like gears for a 2.0 race car?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Navin Johnson
I like most of my gears.. they help me move forward.. anyhoo: I digress: MSX is a nice package for long track: Summit,The Glen, CMP Roebling I cant recommend gears for many tracks west of the mississippi and K,Q,V works well on shorter tracks.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 10-16-2005 at 06:43 AM.. |
