Bottom end knocking!!
My nightmare with my 85 3.2 Carrera continues..... Have had the tensioners done on the car, tappets and rockers checked. I now have a clanging noise from the bottom end my oil pressure is good and there was no debris in the oil. Before I spend a serious amount of pound notes has anyone got any ideas? Thanks again for your help, Ian.
Old 07-21-2005, 08:46 AM
BReyes's Avatar
The only idea that comes to mind is that you speak with a Porsche specialist/friends-remain objective- and weigh all your options carefully.
Was it making the same noise before?
You have a few options. If it is done right you will have a very nice car when you are done.
Good luck.
Regards,
Bernard
Old 07-21-2005, 12:19 PM
The noise is new!
The noise is new!
Old 07-21-2005, 12:55 PM
Is it knocking or clanging? Knocking is likely to be rod knock from a bad bearing. Clanging is more likely to be from a chain hitting something. Maybe the tensioners were installed wrong. A chain could be off of one edge of a sprocket (duplex chain installed on one edge instead of both). Of course these are only guesses. You probably need to take it to a shop that knows these engines to have it checked out.
-Andy
Old 07-21-2005, 01:17 PM
BReyes's Avatar
Then probably rod bearing no.2 or no. 5 went bad. I would not run the car for fear of damaging the crank.
Bernard
Old 07-21-2005, 01:59 PM
abit off center
cgarr's Avatar
Piston slap can be very noisy but should quiet down as the engine warms up..
______________________
Craig
G2Performance
Old 07-21-2005, 02:09 PM
Any backpressure from the blowoff valve (rocker problem).
Have you opened up the oil sill plate and inspected (3.2 might not have these though).
What have you done so far?
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 07-21-2005, 02:15 PM
Wer bremst verliert
JohnJL's Avatar
Is it RHD? Because if it is, you are in serious trouble. You should immediately pack the car in bubble-wrap, put it in a container, and send it to me.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-21-2005, 03:22 PM
BReyes's Avatar
Today, pull the magnetic drain plug. Is it clean? How did it look last oil change?
Bernard
Old 07-21-2005, 09:04 PM
Try shorting out (disconnecting spark) each cylinder in turn. If a cylinder has a bad rod bearing, this will reduce knocking. If the knock still persists, it's probably not a rod bearing. it could be a main bearing or one of the others mentioned.
Hope this helps a little,
Sherwood
Old 07-21-2005, 11:27 PM
drag racing the short bus
dd74's Avatar
Ian - does the knocking go away when the engine is warm?
Old 07-21-2005, 11:30 PM
