Send a message via AIM to EPorsche
Question Help! Need part info
I'm attempting to rebuild an engine for the first time (I love pain) and have come across some part # I cant find. The car is a 77 911 w/2.7. Are RS pistons good/bad?
What are the following as far as alusil/nikasil/year/type/etc:
Cylinders- 90ZN2 W5 and 6
Case- 910 101 102 7R
Engine serial #- 6551182
Pistons- 90P27
Camshaft- (R) 911 105 144 0R (L) 911 105 143 0R
Camshaft tower- 901 105 11 0R
'77 911S w/'81 3.0/MegaSquirt/MSD
'81 911SC stock
Old 07-26-2005, 01:57 PM
camgrinder's Avatar
The camshafts are regular 2.7L CIS "S" cams. Depending on you plans
for the engine, you can get them ground to SC specs as an upgrade.
John Dougherty
Dougherty Racing Cams
Old 07-27-2005, 09:52 AM
Camgrinder,
Are the RS pistons good/bad?
'81 911SC stock
Old 07-27-2005, 10:01 AM
dtw dtw is offline
GAFB
E,
RS Pistons are great but it sounds like you have normal CIS 2.7 pistons. If you are interested in using RS pistons you'll probably want to change to carbs or mechanical injection and also change cams. There are plenty of other mods to do 'while you're in there' that will make your build sheet look better and bank account look worse.
Where in NC are ya?
Several BMWs
Old 07-27-2005, 10:39 AM
Irrationally exuberant
ChrisBennet's Avatar
Re: Help! Need part info
Pistons- 90P27
For the cylinders you mention "W5 and 6". I' don't have time to look it up right now but I'm wondering if those are height groups. Do you have 3 of one kind and 3 of the other flavor by any chance?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-27-2005, 01:54 PM
dtw,
The pistons I have are not CIS, they have valve pocket opposite from each other and one is slightly larger than the other. The cylinders are nikasil. Right now they are at the machine shop. I bought the car in Oct '04 and because of leak decide to rebuild. I already know this not the original engine. My plan is to EFI (TBitz). I'm in Fayetteville (Air Force). I was up your way visiting family last weekend, Six Fork and Lynn area.
Chris,
I think only 1 or 2 had the W6 on them. I did mark the cylinder on them when they were removed.
'81 911SC stock
Old 07-27-2005, 02:26 PM
