911S cis cams
Would 911S cis cams work in am earlier 2.4 911T with carbs?
Old 08-06-2005, 04:34 AM
When you say 911S cis cams I expect you are talking about the very mild (little or no overlap) cams in the 2.7 engines about 1976/77? The cams everybody refer to as "S" cams are definitly not those .If so your T grind is better .I would have "Camgrinder" recommend a regind to a modern cam if what you have is worn or unsuitable.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 08-06-2005, 05:08 AM
camgrinder's Avatar
The 911 S with cis have casting numbers ending with 143 and 144.
These cams would work in place of the original carb T cams but the improvement would be small. Definetly not worth the effort unless your engine was out and you needed to replace the cams.
A better choice would be grinding your T cams to E specs.
John Dougherty
Dougherty Racing Cams
Old 08-06-2005, 08:50 AM
I don't mean to hijack this thread - but I need to replace my 2.7L "S" CIS cams. I was just going to replace them with the same cams - is there any other cam profiles that I should be looking at for a stock rebuild?
Rex
1975 911s
1997 Saab 900s
Old 08-06-2005, 12:21 PM
camgrinder's Avatar
The 2.7 cis S cams can be ground to SC specs. A nice upgrade.
John Dougherty
Old 08-06-2005, 12:49 PM
Autobahn Garage
What will be gained by using SC cams in a 2.7
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 08-07-2005, 08:47 PM
safe's Avatar
Can you use SC cams or, must you regrind the original?
Magnus
Old 08-08-2005, 03:44 AM
I have an article written about the 1975 911 and the author liked driving the standard 911 better than the 911S because the torque of the standard came on at a lower, and more useful, RPM - even tough the "S" was ultimately faster. What can we expect when going from an "s" cam to an "SC"? Does the torque peak at a higher RPM? At the expense of lower RPM torque?
1975 911s
1997 Saab 900s
Old 08-08-2005, 05:17 AM
camgrinder's Avatar
The increase is in the 2000 to 6000 rpm range.
The original SC cams have 49mm, 4 bearings camshafts. The 2.7 has 47 mm, 3 main cams. To use an original SC cam in the 2.7 would require the 3.0 camshaft carriers.
John Dougherty
Old 08-08-2005, 09:00 AM
