Starter bolt on transmission
I am in the process of engine removal using the process identified in Wayne's book (101 projects 911). I have removed three of the 4 transmission nuts, but the hex head bolt where the starter is mounted is stripped.
Any recommendations on the best wat to remove this bolt. Any suggestions would be appreciated. mike 75 911S |
A grinding or cutting wheel for a dremel may fit up there. No way to get an angle grinder in. I think you're in for a long job there.
I had this problem once, that is why I pull the motor and tranny together. I ended up doing that as I could not see how I was going to get it off. The worst part was some jack@ss mechanic at a well known p-car shop here had just put a new clutch in it and stripped the head off that one barrel nut. Wonder if they shoulda replaced the 50c nut.........
Jeff |
| All times are GMT -8. The time now is 07:13 AM. |
