-   -   head studs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/235676-head-studs.html)
bbh03 08-11-2005 07:58 PM
head studs
Anyone heard of the manufacturer of head studs called Canyon?
Porsche_monkey 08-12-2005 04:12 AM
No, and I would not recommend you venture into unknown teritory with a Porsche and experimental head studs. Do some searching for on this site for ARP.
asphaltgambler 08-12-2005 05:12 AM
DITTO
JeremyD 08-12-2005 06:17 AM
or raceware - or Supertech like I have...
Jeff Alton 08-12-2005 07:30 AM
Jeremy did I read right in one of your previous postst that the Supertec studs go in with BLUE loctite?
Jeff
JeremyD 08-12-2005 07:34 AM
Yep - that's what Henry provides - with the Supertech Head studs you have to bottom out the studs too - all the way to the bottom, then 1/2 turn.
Jeff Alton 08-12-2005 07:44 AM
Ahhh, that makes a little more semse then, I thought I was aging too fast! Got an overall first impression of those headstuds?? I am thinking of doing those or ARP but had originally planned on just using steel....
Jeff
JeremyD 08-12-2005 08:00 AM
Like works of art - beefy works of art - but works of art.
Porsche84 08-14-2005 05:59 AM
I'd suggest that you carefully measure the length of the stud after it is installed. I missed this on my first engine rebuild and the allen nuts are a problem if your studs are a bit too long. If the studs are too short, the nut does not get a full engagement. I believe the length was 130 mm. It is in some obsure place in Bruce Andersen's book. If the stud manfacturer is suggesting that you bottom them in the holes and turn 1/2 turn, you may end up with short studs. I like the red loctite, you can set the stud length where it should be and it is easy to remove with heat. Good luck.
JeremyD 08-14-2005 07:49 AM
Not critical with the supertech head studs
Jeff Alton 08-14-2005 10:22 AM
I believe by bottoming out the stud and giving it an extra half turn eliminates the need for the red loctite and lets you use the blue, I think. I am guessing they do not use a barrel nut as well..... Making height not quite as much of an issue. If I remember off the top of my head (ha) the stud length is 135mm.
Jeff
JeremyD 08-14-2005 11:30 AM
135mm - No barrel nut - 12 point nut instead.
JeremyD 08-15-2005 12:34 PM
Knew I had a picture somewhere...
http://forums.pelicanparts.com/uploa...1124138065.jpg
bbh03 08-15-2005 12:38 PM
Really? No one has heard of the Canyon studs? I have heard about them from two independent people. I will try to get more info...
Porsche_monkey 08-15-2005 12:46 PM
Canyon Studs?
Here's your link...
http://www.lioncanyonranch.com/listHorses.aspx?cat=Stud
Porsche84 08-15-2005 01:05 PM
Very Funny!!!! Do you use a metric wrench to torque the nuts?
Porsche_monkey 08-15-2005 01:07 PM
Such a good joke, such an arcane topic. Story of my life.
bbh03 08-15-2005 01:24 PM
Originally posted by PBH
Canyon Studs?
Here's your link...
So a set of those are good for what, 24 hp right? Haha!
JeremyD 08-15-2005 04:03 PM
and probably the best representation of performance gains...
sammyg2 08-16-2005 02:47 PM
Unless you are building a full race killer motor, the stock steel studs will do just fine (no dilivar, ever!).
If you are building a monster go with the really expensive stuff, it's a little better than stock.
JeremyD 08-16-2005 06:36 PM
Let's see - stock steel studs are $18 per, washer + bolt times 24 gets you into the $550 range (per pelican)- supertech are $650 - so for $100 you wouldn't upgrade to get a stud that's guaranteed for life?
Jeff Alton 08-16-2005 06:41 PM
For me I think I am going with the factory steel studs.I pay about 60% of that for them and the top row are steel already and looked good when I had the motor apart last spring.... I also have a good selection of new nuts and washers. However, the lure of doing it "right" migh just make me buy the supertechs or ARP. Everything else is being upgraded, so why not this stuff too?
Jeff
Mark McClure 08-16-2005 09:21 PM
At what point is the standard steel not enough.....? Since these things are held tight with no movement (apparently) The only thing that can have an impact on their effectiveness is the CR that you are using, ie the amount of outward force that is placed on them.
If the case threads are ok.....what is the relative safe breaking/scretching force relative to CR.
Cheers
Mark.....
ChrisBennet 08-17-2005 04:09 AM
I agree with Jeff. Pelican sells the 993 steel head stud for $9.28 and since the top row of studs are usually fine, you're looking at a cost of only $112.
Porsche part # 993.101.172.02, Pelican part # OEM-99310117202. If you put the Porsche part # in the grey "Search Pelican Parts" box at the top left of this page and you can find it that way. Using the Pelican part # doesn't seem to work though.
-Chris
sammyg2 08-22-2005 09:42 AM
I replaced my dilavar lower studs with steel studs from pelican. I paid under $10 each for them, they are the steel 993 studs (not fully threaded).
So I paid under $120 for them. If I had replaced all 24 (why in the world would I do that?) it would have cost me less than $240.
Compare that to $650 for the supertech studs that are IMO all bling and no zing on anything but a full race engine, well you get my point.
$410 extra spent on something that is not necessary is not necessary ;)
JeremyD 08-22-2005 09:56 AM
Well, I live 40 feet from the ocean so corrosion is pretty important to me. Steel rusts - all it takes is a nick on the epoxy coating on a steel stud in my neck of the woods. So bling for something that nobody will see? methinks not.
JeremyD 08-22-2005 10:05 AM
Oh and I based my decision on pricing that Pelican currently has on their website:
http://forums.pelicanparts.com/uploa...1124733851.jpg
Jeff Alton 08-22-2005 10:58 AM
I am not saying they are a bad idea! Quite the oppositte infact, I just didn't think that I need them. I am currently paying 11.50cdn for a epoxy coated factory steel stud so you can see why I am leaning that way...
Cheers, Jeff
p911sc 07-03-2006 09:47 PM
I am currently considering the Supertech Studs for my 1983 911 SC rebuild and was reading old posts.
I'm stumped though, why does supertec recommend blue loctite instead of the red? If I read the directions posted above, the studs are bottomed out and then backed off a half turn, so it shouldn't have anything to do with the bottoming??
Rick
greg bradbury 07-04-2006 06:52 AM
Red loctite is for studs and blue is for the nuts. The rational is that if you put red on the stud and blue on the nut when you come to the time to disassemble the nut will come off without the stud backing out. Since the nut on the head bolt isn't loctited the stud can go in with blue or red and there shouldn't be a problem with the stud backing out.
That's the way I see it anyway.
Regards,
Greg
patkeefe 07-04-2006 07:02 AM
I'm thinking of putting in Henry's studs on my 3.0 SC turbo engine. I currently have on order the later model all threaded studs (on a recommendation). Are these all threads steel studs, or are they a Dilivar derivative (I suspect they are)? If they are, I'm definitely going with the Supertec stuff. Since I'll be running a bit of boost, I'd like to keep everything together best I can. I also think the ARP or Raceware stuff is really expensive, and likely a bit of overkill on an engine that may never develop 275 HP.
Pat
Determined 07-04-2006 08:06 AM
I recently replaced mine in my 3.2L project with ARP's, I bottomed them out then backed them off 1/4 turn. I used red loctite after all, for removal in the future I'll just use heat. I measured the heights and they were nearly dead-on at 135 mm. I even took some side-by-side pictures comparing to standard steel studs...take a look below:
Regards,
Alex
http://forums.pelicanparts.com/uploa...1152029046.jpg http://forums.pelicanparts.com/uploa...1152029071.jpg http://forums.pelicanparts.com/uploa...1152029086.jpg http://forums.pelicanparts.com/uploa...1152029105.jpg http://forums.pelicanparts.com/uploa...1152029124.jpg
Henry Schmidt 07-04-2006 12:52 PM
Nice pictures
The pictures of the ARP studs clearly show that the threads on the nut end are not fine thread like the ad on Pelican and other places state.
A fine thread stud is clearly a better design and ARP has tried to capitalize on the Supertec design without actually using it. ARP studs also use a remarkably similar material to Supertec studs after we sent them a sample to quote.
When ARP was confronted with these discrepancies they deny the advertising errors are their responsibility and claimed they chose the materials independent of our sample.
One thing is for sure, Supertec is the only Porsche head stud kit that offers this superior design, a life time warranty and a quality that is well worth the price.
BTW: installed stud length only has meaning when an allen style head stud is used. It should also be noted that cylinder height, spigot height and head thickness will all effect the true stud length. The book fails to mention this fact.
Ad copy from Pelican parts catalog.
ARP Cylinder Head Stud Kits
The ARP Custom Age 625+................................ studs, these Porsche 911/914-6/930 studs have rolled threads, fine threads at the head end of the stud for more accurate torquing, and include a 12-pt hardware kit, complete with nuts and washers, and ARP's special torquing lube.
SUPERTEC HEAD STUDS , THE FINEST STUDS ON THE MARKET
http://forums.pelicanparts.com/uploa...1152046435.jpg http://forums.pelicanparts.com/uploa...1152046460.jpg http://forums.pelicanparts.com/uploa...1152046497.jpg
p911sc 07-04-2006 08:52 PM
Henry,
What is the specification on the fine thread end. M?? x ??
Rick
Henry Schmidt 07-05-2006 03:59 AM
Supertec studs have a longer 10x1.5 mm thread at the case end and a longer 10x1.25 mm thread at the nut end.
These longer threads make the stud very suitable for custom built engines that use non standard strokes. When building longer stroke or longer rod engine special stud lengths are desirable. Supertec studs offer this longer length and superior fit on stock engines.
The 12 point nuts offer a fitment for twin plug application that stock Porsche head nuts do not. When using stock head nuts and studs with twin plug there is a interference that must be remedied. Some people use a 6 point nut as a remedy.
No such interference exists with our stud & nut combination.
