head studs
Anyone heard of the manufacturer of head studs called Canyon?
Old 08-11-2005, 08:58 PM
Slumlord
Porsche_monkey's Avatar
No, and I would not recommend you venture into unknown teritory with a Porsche and experimental head studs. Do some searching for on this site for ARP.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-12-2005, 05:12 AM
Still Doin Time
asphaltgambler's Avatar
DITTO
Old 08-12-2005, 06:12 AM
MBruns for President
JeremyD's Avatar
or raceware - or Supertech like I have...
Old 08-12-2005, 07:17 AM
Jeff Alton's Avatar
Jeremy did I read right in one of your previous postst that the Supertec studs go in with BLUE loctite?
Jeff
www.turn3autosport.com
Old 08-12-2005, 08:30 AM
JeremyD's Avatar
Yep - that's what Henry provides - with the Supertech Head studs you have to bottom out the studs too - all the way to the bottom, then 1/2 turn.
Old 08-12-2005, 08:34 AM
Jeff Alton's Avatar
Ahhh, that makes a little more semse then, I thought I was aging too fast! Got an overall first impression of those headstuds?? I am thinking of doing those or ARP but had originally planned on just using steel....
Jeff
Old 08-12-2005, 08:44 AM
JeremyD's Avatar
Like works of art - beefy works of art - but works of art.
Old 08-12-2005, 09:00 AM
Grand Am/IMSA Data Guy
Porsche84's Avatar
I'd suggest that you carefully measure the length of the stud after it is installed. I missed this on my first engine rebuild and the allen nuts are a problem if your studs are a bit too long. If the studs are too short, the nut does not get a full engagement. I believe the length was 130 mm. It is in some obsure place in Bruce Andersen's book. If the stud manfacturer is suggesting that you bottom them in the holes and turn 1/2 turn, you may end up with short studs. I like the red loctite, you can set the stud length where it should be and it is easy to remove with heat. Good luck.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 08-14-2005, 06:59 AM
JeremyD's Avatar
Not critical with the supertech head studs
Old 08-14-2005, 08:49 AM
Jeff Alton's Avatar
I believe by bottoming out the stud and giving it an extra half turn eliminates the need for the red loctite and lets you use the blue, I think. I am guessing they do not use a barrel nut as well..... Making height not quite as much of an issue. If I remember off the top of my head (ha) the stud length is 135mm.
Jeff
Old 08-14-2005, 11:22 AM
JeremyD's Avatar
135mm - No barrel nut - 12 point nut instead.
Old 08-14-2005, 12:30 PM
JeremyD's Avatar
Knew I had a picture somewhere...
Old 08-15-2005, 01:34 PM
Really? No one has heard of the Canyon studs? I have heard about them from two independent people. I will try to get more info...
-Brian
Old 08-15-2005, 01:38 PM
Slumlord
Canyon Studs?
Here's your link...
http://www.lioncanyonranch.com/listHorses.aspx?cat=Stud
84 Cab - sold!
Old 08-15-2005, 01:46 PM
Porsche84's Avatar
Very Funny!!!! Do you use a metric wrench to torque the nuts?
Jerry Austin
Old 08-15-2005, 02:05 PM
Slumlord
Such a good joke, such an arcane topic. Story of my life.
84 Cab - sold!
Old 08-15-2005, 02:07 PM
Originally posted by PBH
Canyon Studs?
Here's your link...
So a set of those are good for what, 24 hp right? Haha!
Old 08-15-2005, 02:24 PM
JeremyD's Avatar
and probably the best representation of performance gains...
Old 08-15-2005, 05:03 PM
Unregistered
sammyg2's Avatar
Unless you are building a full race killer motor, the stock steel studs will do just fine (no dilivar, ever!).
If you are building a monster go with the really expensive stuff, it's a little better than stock.
Old 08-16-2005, 03:47 PM
