up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Thoughts on a 2.7SS ?
For no good reason, I was thinking today about a 2.7 engine using a short-stroke crank and 93mm Nickies/JEs. I wouldn't be doing this for a very good while, but would it be worth it? Everything besides the 93mm P/C would be 2.2S parts (MFI, heads, ports, cams, crank, etc.). Case would be a 7R probably. I imagine it would basically run and sound like a 2.2S with a little more volume, meat and an extra half liter or torque and hp. What do you guys think?
Scott Kinder
kindersport @ gmail.com
Old 08-14-2005, 09:47 PM
3 restos WIP = psycho
kenikh's Avatar
These are the 2.9L P/Cs, correct (long stroke) on a 66mm crank? Would be a cool motor, but would suffer from the same detractions that the 2.9 does: THIN cylinder walls.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-15-2005, 08:55 AM
I would rather be driving
jpnovak's Avatar
I too think this is not a good idea. The thin cylinder walls are one thing. You also have case machining which leaves little material left to hold onto those very important head studs. Otherwise it sounds like a fun motor. Now, an Aluminum case might be a different story...
Old 08-15-2005, 10:01 AM
kenikh's Avatar
I know for a fact that Scott has an early Al case sitting around...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-15-2005, 10:14 AM
jpnovak's Avatar
The same reason I said that...
Old 08-15-2005, 02:53 PM
YTNUKLR's Avatar
Kenik, I have talked to Charles Navarro at LNE, he said since his forgings are way stronger than the Mahle cylinders, you can run even 93.5mm on the street! Sounded valid, anyway. I do have an early Alu case but they are just so much harder to come by than the 7R!
Thanks for the input so far!
Scott Kinder
Old 08-15-2005, 03:14 PM
