ID these HEs
Edit: Nevermind - I think they are B&B.
Old 08-12-2005, 09:47 PM
Bill Verburg's Avatar
They are B&B, but not all B&B are the same and there are cutom versions out there as well.
Those are B&B, Carrera, either 1.5" or 1.625" I.D., well used I might add
Bill Verburg
Old 08-13-2005, 10:27 AM
They should be usable though right? I thought these things were pretty much indestructable. Maybe bead the outside and ? the inside???
Old 08-14-2005, 10:51 AM
Yes, that's all just surface tarnish, those things are well built, the stainless will last forever.
I would just use them as is, except any oil that got into the exhanger part should be cleaned out.
Bill Verburg
Old 08-15-2005, 05:27 AM
There is oil in the header portion of one of them. Should I just flush it with solvent and dry it?
-Brian
Old 08-15-2005, 08:38 AM
If there is oil inside the exhanger(not the exhaust pipe) you can try to clean it out, but it's usually baked on pretty well. Try solvent but be very carefull when it's time to put back into service, you will want to be sure all of the fumes are vented overboard before you need heat in the cabin.
Bill Verburg
Old 08-15-2005, 01:27 PM
Nothing in the exchanger portion, and I can;t think of a reason for oil to ever get in there. Oil did come out of the exhaust portion on one side though.
-Brian
Old 08-15-2005, 01:40 PM
MBruns for President
JeremyD's Avatar
They will clean up like new. The headers are built like battleships (and hence a good value on the used market.
Old 08-15-2005, 05:07 PM
If you look closely where the stubs come up from the exchanger there is not a solid seal.
Oil can drip down the stub and into the exchanger chamber.
Bill Verburg
Old 08-15-2005, 06:45 PM
