blue82coupe's Avatar
Case sealing
I've come across conflicting info on case sealing. Should the sealant be applied to both case faces.. or just the right hand side? Dan
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 08-13-2005, 08:43 PM
Jubbie's Avatar
I did just one side (the side with holes not studs) and no leaks yet
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 08-13-2005, 08:57 PM
Jeff Alton's Avatar
Just the one side. There is a HUGE thread on this on this forum, its a good read....
Jeff
www.turn3autosport.com
Old 08-13-2005, 10:26 PM
Thanks fellas.. I'll do a search. Dan
Old 08-14-2005, 03:50 AM
Jeff Alton's Avatar
I hope I didn't sound harsh. If I could figure out how to post a llink to a thread, I would have done it!! The thread is not very old.
Jeff
Old 08-14-2005, 11:26 AM
Hey Jeff.. not at all. I feel sometimes my posts and replies are a bit to "pointed." My biggest problem, is that my typing and composition skills suck. Anyhow ,I did a search and I'm still conflicted. I'm confident that my measurements and clearances are correct. ..just don't feel that way about my case sealing. I'm not in a hurry though. Dan
Old 08-14-2005, 12:35 PM
Jeff Alton's Avatar
It is kinda the one thing you REALLY have to get right the first time. A lot of other things can be fixed later or redone etc. You can't even check your work until its fired up!
Jeff
Old 08-14-2005, 01:40 PM
You can say that again..HA,HA. I 'm fairly certain I'm not going to use Lockite 574. I'm leaning towards Dow 730, Three bond 1104,or Dirko.Everything awaiting this decision. Dan
Old 08-14-2005, 03:40 PM
rw7810's Avatar
The 574 is good stuff, used by pro builders for years, not to mention the factory. The key is to go thin. I built my 2.2 last year from a 35 year old mag case and (knock on wood) no leaks. I've also noticed nuts and bolt heads that were accustomed to being soaked in oil now in a somewhat rusty condition.
Robert Williams
70' 911T
Old 08-14-2005, 05:15 PM
