1972_911T's Avatar
Piston Cleaning
Whats best for cleaning the carbon off the tops of pistions I was thinking oven cleaner would work well but am A bit worried this may damage the pistons as its caustic, Any advice?
Old 08-25-2005, 11:39 AM
Irrationally exuberant
ChrisBennet's Avatar
Wire wheel works pretty well. Just soaking the tops in water will soften the carbon quite a bit.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-25-2005, 11:59 AM
stevepaa's Avatar
I did what Chris said. Wire wheel and a little brake clean. And then I polished them a tad and the heads.
steve
old rocket inguneer
Old 08-25-2005, 12:10 PM
3 restos WIP = psycho
kenikh's Avatar
I haven't done it to pistons, but boiling exhaust parts has done the trick in softening carbon build up dramatically.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-25-2005, 12:54 PM
David's Avatar
The best thing I've found is the gallon can of Berryman's carburator cleaner. It's not the same stuff as in the spray cans. It smells like creosote (unless the EPA has outlawed it, it's been awhile since I bought my can). Put a piston or two in it for a few hours or a day, take it out and clean it in regular parts cleaner, and voila a shiny clean piston. It also works for soaking carburetor parts, who knew?
Old 08-25-2005, 02:41 PM
Somewhere in the Midwest
MotoSook's Avatar
Gunk has carb cleaner in a gallon paint can that comes with a little basket in it for soaking small parts...a piston would fit in that basket if you want to do one at a time, but I just poured some out of the container into an aluminum pan about 1/8" or 1/2" deep and put the pistons in upside down. You can adjust the depth if your ring grooves need cleaning too.
After a day soaking (while you are at the work), the carbon slides right off. I use an old tooth brush.
The Berryman works the same...
Old 08-25-2005, 02:50 PM
walt's Avatar
Berrymans is very good but use it outdoors. Carbon comes right off after an overnight soak.
Walt
82SC 3.0
81SC 3.6
Old 08-25-2005, 03:31 PM
89red911's Avatar
I used crab cleaner and a small brass brush to clean my pistons worked pretty good. A friend of my cleaned his with a 2 liter of coke and a cookie sheet. he said after 24 hours of that his pistons were like new. i never saw them so i cant say for sure
Shiny side up, Rubber side down, Its the fastest way around the track.
Old 08-25-2005, 06:32 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
What kind of pistons? Whatever you do, make sure you don't use anything too abrasive (media blasting, harsh chemicals, etc) that would remove any coatings, like on the Alusil CIS pistons.
A hand held steamer works wonders, makes the carbon flake off.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 08-25-2005, 07:52 PM
Addicted to Racing
edbaus's Avatar
There is a product called piston kleen. Works very well.
If you need the info I can look it up tonight.
Ed Baus
GT4s
Old 08-31-2005, 10:58 AM
MBruns for President
JeremyD's Avatar
I used berrymans in a paint can. Be careful because it produces some gas and the lid can fly off with a POP - it'll scare the crap out of you working on your car in the middle of the night (like I usually do)
Old 09-01-2005, 10:29 AM
dion914-6's Avatar
...and this is why I stopped drinking all cola products about 2 years ago. I read stuff like this, tried (it works on rust too), and it scared the ***** out of me.
Dion
Old 09-01-2005, 07:57 PM
