-   -   head stud qurstion?????? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/238117-head-stud-qurstion.html)
jpc1818 08-27-2005 04:01 PM
I have the engine out. I'm replacing the clutch, and all the seals that I have access too, including the rocker shaft seals, which by the way were leaking like crazy. Anyway, I found one broken lower head stud. The engine is out but not totally apart. The engine was defiantly rebuilt, because of the engine sealing used all over the inside. too replace or not? That is the question?
ChrisBennet 08-28-2005 04:16 AM
If you were one of my buddies here in the North East I'd tell him to run it easy this fall and rebuild it this winter. (We've got a month or two of driving weather before 6 months of winter.)
As you probably know, seeing sealant "all over the inside" is not the sign of a knowledgable rebuilder.
-Chris
BReyes 08-28-2005 10:02 AM
Sorry about the results of your inspection. You are looking at a top end rebuild. Not sure what you mean about the sealant on the inside, but I would want it to be correct once completed. Sounds like you have the skills to do some of the work. How many miles since the heads were reworked? You may want to have them dissassembled and the valves/guides checked out. PNC may be in spec.
Good luck.
jpc1818 09-25-2005 03:58 PM
I found only the one head studd. Since I have read its a frequent problem. So I put the engine back together and its running awesome. Thanks for the help and suggestions
