loctite 574 removing
Hello
Sorry to ask again, but i didn't find threads to explain how to remove "faster" the 30 years old sealant of my RS engine....:) many thanks for advices or links. Philippe |
Chris
your a kind guy as you almost answer all my questions. You're welcome home if you have a trip to taste burgundy wines.:D Philippe |
The gasket remover is also known as Loctite 80646. In case you can't find Permatex, Wurth has a similar product. I haven't tried the Wurth gasket remover but it wouldn't surprise me if it was exactly the same stuff with a different label. I know Wurth sells Loctite 574 under their own label. -Chris http://forums.pelicanparts.com/uploa...1125320463.jpg |
| All times are GMT -8. The time now is 10:10 PM. |
