goldgunner's Avatar
Internal Throttle Body Components - Motronic
In dismantling an old and used 84 carrera manifold assembly, in preparation to convert my 80 SC to EFI, I've self inflicted some grief...
The Motronic carrera throttle body looked to be very dirty in and out, so ' naturally' I disassembled towards cleaning, bead blasting and plating some components.
Result: the butterfly valve shaft could be straighter, but more importantly the threads are now gone from one of the two - in the shaft - that hold the flat round butterfly valve itself...
So, has ANYONE a schematic with part numbers of the INTERNAL components for this throttle body / housing?
The PET part number for the housing is:
930.110.519.03
Which is actually the p/n for the assembly with the 'plug in' components.
Of course, it would be best to have a schematic, with part numbers for the INTERNAL mechanical components, as well as the EXTERNAL mechanical components of the throttle body.
Anyone? Please?
Or - Ideas?
thanks!
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 09-05-2005, 12:53 PM
Still Doin Time
asphaltgambler's Avatar
The reason the threads are gone is because the tiny screws are peened or flatened where they protrude through so as not to work loose or fall out. The shaft is very flimsy along the area where the plate bolts to minimize the cross-section.
Probably best bet would be to find another throttle body housing and start over. Sorry.
Old 09-05-2005, 04:17 PM
