dmcproud's Avatar
79 SC w/ 44,000 miles need chain tensioners yet?
subject says it all
am worried about waiting too long to put in the Carrera tensioners.
How much for parts?
How much for labor?
thank you
Old 09-02-2005, 02:33 PM
walt's Avatar
Never to early to make the conversion. Its been a long time since I priced this but maybe 375-400 for parts and the same for labor. Its worth the money just for the peace of mind.
Walt
82SC 3.0
81SC 3.6
Old 09-02-2005, 03:08 PM
Somewhere in the Midwest
MotoSook's Avatar
Just get the stops and forget about the pressure fed tensioners. Do a search on tensioners and you'll see the discussion.
Old 09-02-2005, 05:20 PM
do pressure fed...if you have the $....compared to waiting do stops IMHO don't do nothing
Sold: 1989 3.2 coupe, 112k miles
Old 09-02-2005, 06:13 PM
Unregistered
sammyg2's Avatar
I agree with Souk.
Old 09-05-2005, 08:29 AM
fastfredracing's Avatar
The last SC that I rebuilt had the stops installed on 930 tensioners and one tensioner had failed and hammered the stop into oblivion. It was smashed up so bad that it had broken one of the small bolts on the stop and I believe that it was nearly ready to fail itself. I never heard this motor run, but I would imagine that it would have made some noise. I prefer the carrera tensioners, but I guess if you use the stops and you are alert to any noise coming from the engine, they would be O.K.. But. While not just upgrade while you are in there and be done and sleep easy at night. Just my 2 cents..
Old 09-05-2005, 10:31 AM
Unregistered
sammyg2's Avatar
Sleep easy at night?
I have heard of more "new" carrera tensioners failing than old style tensioners failing.
Old 09-05-2005, 01:56 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
Okay, this is a bit confusing to me.
Newbee Question:
Is there a diagnostic or test that could tell strength (or something similiar) of the existing chains?
If it fails, I get the upgrade.
If it passes, I do nothing.
Since it looks like no matter where I get the kit (Pelican or others) plus labor, I'll be in for a grand ($1000 USD) for the upgrade that could go to baby's college fund...
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 09-12-2005, 11:16 AM
acapella8's Avatar
Update, as it turns out, I already have the updated hydraulic tensioners. I was directed how to check for the T and oil lines, mine leak a bit -- but may just need some tightening up.
[GruppeB # 978]
Old 09-13-2005, 07:41 AM
