goldgunner's Avatar
Flywheel Wear - Very Close To Limit
80 911SC 3.0 to 3.2
Just got the p&c's, crank and flywheel back from the shop after polishing and balancing, along with the measurement results.
The flywheel came back with a measurement of 8.62mm
Not much at all over the minimum 8.5mm
Should I use this flywheel - as is?
Or should I replace the flywheel?
And balance again the crank & new flywheel?
Or use the new flywheel as is?
Thanks!
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 09-24-2005, 06:17 AM
Use it!
Its well in spec..
Kind regards
Old 09-24-2005, 09:35 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Use your existing flywheel. The next time you replace the clutch you will need to replace it.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-24-2005, 09:52 AM
