Short stroke 2.6 vs. Short stroke 2.8
The question says it all. Besides the displacement difference (173cc), it seems the only difference is the heads:
2.6 (CR 10.3:1)
Valves I46/E40
Ports I36/E35
Combustion chamber 68cc
2.8 (CR ?)
Valves I49/E41.5
Ports I39/E35
Combustion chamber 90cc
I’d like to know which is a more potent engine in terms of power band, torque, responsiveness, and characteristics.
TIA
Old 09-10-2005, 10:24 AM
jluetjen's Avatar
Well the 2.8 that you listed has bigger valves and ports which allows more air flow, so in conjunction with the extra capacity and higher rev's (that the larger valves and ports will allow), the 2.8 example should make more HP. But that assumes that the pistons cams, intake, exhaust and so on are configured correctly.
The reality is that the factory 2.8 RSR engine was a configuration that was specifically developed to fit the FIA's rules. If you built a 2.7 the same way that the factory built their 2.8's (which many people have done), you'll have almost the same HP, if not more due to more modern gas.
What are you trying to get to?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 09-10-2005, 01:09 PM
3 restos WIP = psycho
kenikh's Avatar
Re: Short stroke 2.6 vs. Short stroke 2.8
Originally posted by blue72s
2.6 (CR 10.3:1)
Valves I46/E40
Ports I36/E35
I wouldn't use those port specs. I'd open them up. 38mm ports at least.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-10-2005, 09:16 PM
